29 Menu Item Waste
Does not post to sales
Deplete inventory
Service Total and Print functions close a waste check
When menu item waste occurs, authorized workstation operators can begin a menu item waste check and then enter menu items to waste or donate. Managers can generate waste reports by revenue center, menu item, employee, and waste reason. Depending on the reasons for waste, managers can take action to reduce inventory loss. You can differentiate waste checks from other checks in the Employee Journal Report and the Check Journal Report by the Waste Check banner on the check header.
Table 29-1 Differences Between Waste Checks and Guest Checks
| Function | Menu Item Waste Checks | Guest Checks |
Kitchen Display Systems (KDS) or screen lookups display the check |
No |
Yes |
Reopen a closed check |
No |
Yes |
Apply discounts |
No |
Yes |
Apply taxes |
No |
Yes |
Apply service charges |
No |
Yes |
Apply guest count |
No |
Yes |
Return item |
No |
Yes |
Edit seat |
No |
Yes |
Split check |
No |
Yes |
Gift card or credit card operations |
No |
Yes |
Send and Stay |
No |
Yes |
Hold and Fire |
No |
Yes |
Transaction void |
No |
Yes |
Transaction return |
No |
Yes |
Menu item availability |
No |
Yes |
Configure employee privileges to begin waste checks and run waste check reports
Define reasons for menu items declared as waste
Configure waste receipt headers and trailers
(Optional) Hide price details on waste checks
Add a Declare Waste button to the touchscreen page
