Setting the Tare Weight for a Menu Item
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Maintenance.
  2. Click Search to show all menu items, and then double-click a menu item master record.
  3. Click the Definition Records tab in the lower area of the screen.
  4. In the Tare Weight field, enter the weight of the empty package for an item that is sold by weight (for example, the weight of the salad container at a salad bar, where salad is sold by weight).
    The Tare Weight should not be more accurate than your scale can measure so that the application does not round. For kilograms this is to the thousandth 0.000, for pounds the hundredth 0.00, and for ounces the tenth 0.0.
  5. Click Save.
  6. Select the Enterprise, property, revenue center, or zone, click Setup, and then click Control Parameters.
  7. Click the Options tab, and then select 13 - Convert Weight to System Unit of Measure.
    You must set this option in the United States to comply with the Department of Agriculture Weights and Measure requirements. Setting this option allows the POS client to convert the item weight to the property’s UOM if the UOM received from a scale does not correspond to the UOM set from the Property Parameters module.
  8. Click Save.
