Allowing Assigned Receptacle Access and Counts
ECM requires that you assign a workstation operator to a till or server bank receptacle session to perform transactions against the session. Managers need access to work within these receptacle sessions without being assigned to the sessions. You can create an Employee Class for management workstation operators with a configuration set that allows them to perform transactions against the till or server banking session without prior assignment.
- To prevent the workstation
operator from performing more transactions after counting a receptacle
session, select option 28 - Prevent Transactions once a
Count has been Performed.
Starting with release 19.2.1, option 28 is available. Selecting 28 does not prevent the workstation operator from adjusting a count or from transferring funds out of the counted receptacle.
If option 27 is disabled and option 28 is enabled, the workstation operator can perform more than one count and can perform more transactions following a count.
Related Topics
- Configuring Data Retention Limits
- Configuring ECM Privileges and Permissions
- Allowing Users to View Blind Totals
- Configuring Accounting Methods for Users
- Allowing Users to Override Employee Class Options
- Creating, Editing, and Deleting Cash Management Reasons
- ECM Workstation Hardware
- ECM Configuration Levels
Parent topic: Enterprise Cash Management
