Tracking Tender Transaction Items
You can identify tender media transaction items (for example, cash, check, and other currency based tenders) that you want ECM to track.
  1. Select the Enterprise, zone, or property, click Configuration, and then click Tender/Media.
  2. Double-click the tender media record.
  3. Click the Options tab, and then click the Ops Behavior subtab.
  4. Select the appropriate Tender Media options, and then click OK.
    • 4 - Use with Currency Conversion: Select this option for the foreign currency class payment tender.
    • 91 - Cash Management Transaction Item: Select this option to include the tender record in ECM tracking and reporting.
    • (Optional) 92 - Affects Cash Pull Threshold: Select this option to have transactions performed for this tender record affect the Cash Pull Threshold Set balance. Select this option for tender records that represent a loss if they are lost or stolen (for example, cash and checks). You must select option 91 to use option 92.
  5. Click Save.
