Configuring Tip Tracking and Reporting
  1. Select the Enterprise level, click Configuration, and then click Roles.
  2. Select the type of role (for example, server or bartender).
  3. Click the Operations tab, and then select the appropriate options as described in the following table:
    Table 11-8 Tip Tracking and Reporting Privileges
    Option Number Privilege Name Allow the Employee to... Recommended Role
    65
    Authorize/Use the [Direct Tips] and [Indirect Tips] Keys
    Use the Direct Tips and Indirect Tips function keys to declare cash tips received, and to authorize others to do so
    Server
    66
    Authorize/Use the [Direct Tips] and [Indirect Tips] Keys for Another Employee
    Use the Direct Tips and Indirect Tips keys to declare cash tips received by another employee, and to authorize others to do so
    Manager
    187
    Authorize/Perform the Pay Tip Out To Others Keys
    Give cash tips to others, and to authorize non-privilege employees to do so
    Server
    188
    Claim Tips From Other Employee
    Receive a tip from another employee
    Server
    189
    Authorize/Perform Edit Of Any Tip Outs
    Edit cash tips given to other employees, and to authorize non-privilege employees to do so
    Manager
    195
    Allow Edit of My Tip Out
    Edit tip outs
    Server
    303
    Authorize/Perform a zero Direct Tip
    Enter a $0 direct tip without requiring authorization to do so when clocking out
    Manager
    31010
    Run Employee Tip Report
    Run the Employee Tip Report
    Manager
    31045
    Run Employee Tip Track Report
    Run the Employee Tip Track Report
    Manager
  4. Click Save.
  5. Select the revenue center, click Setup, and then click RVC Parameters.
  6. Click the Options tab.
  7. To print a validation receipt when a tip-out or tip edit operation occurs, select 7 - Validate Employee Direct/Indirect Tips Declared Transactions.
  8. Assign a validation printer at the property level:
    1. Select the property, click Setup, and then click Workstations.
    2. Click the Printers tab.
    3. Select a Validation Printer, and then click OK.
    4. Click Save.
