Configuring Tip Track Buttons
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
  2. Open the page on which to place tip track buttons.
  3. On the Edit tab, select the page area in which to define the tip track functions.
  4. Click Button.
  5. On the General subtab, enter the button name Tip Track Tip Out in the Legend field.
  6. Select Function from the Type drop-down list.
  7. Click the black arrow directly beneath the Type drop-down list, select Tips from the Type section, select Tip Track Tip Out from the Results section, and then click OK.
  8. Repeat Steps 3 through 7 to create the following buttons:
    • Tip Track Edit My Tips
    • Tip Track Edit
  9. Click Save.
