Assigning Privileges for Engagement Administrative Users
You need to assign privileges for Engagement administrative users to access, add, and change new pages or page assignments in the EMC.
  1. Select the Enterprise level, click Configuration, and then click Roles.
  2. Insert a record for the role (for example, host, bartender, server, manager, or administrator), and then click OK.
  3. Double-click the role type.
  4. Click the EMC Modules tab.
  5. For the Engagement Page Design and Engagement Page Assignment modules listed in the File column, select one or more of the following privileges:
    • View: Grants access to view a module. You must select View so that employees in the role can open the module.
    • Edit: Allows employees in the role to edit Welcome and Hub pages.
    • Add: Allows employees in the role to add Welcome and Hub pages.
    • Delete: Allows employees in the role to delete Welcome and Hub pages.
  6. Click Save.
