Voiding Points on a Re-opened Check
To allow workstation operators to void loyalty points issued on re-opened guest checks, the check number must remain the same after reopening a check. By default, a guest check number increments each time a workstation operator re-opens the check, preventing the voiding of points due to check numbering mismatch.
Related Topics
Parent topic: Loyalty and Gift Card Interfaces and Drivers
