- Configuration Guide
- Loyalty and Gift Card Interfaces and Drivers
- Configuring Loyalty and Stored Value Privileges
- Select the Enterprise level, click Configuration, and then click Roles.
- Select the role type, click the Operations tab, and then click the Stored Value Cards subtab.
- Select the appropriate options for the privileges. The
following table summarizes the privileges associated with Loyalty
and Stored Value functionality.
Table 48-2 Loyalty and Stored Value Privileges
Section Option Number Privilege Name Select This Option to Allow Employees to... Issue Functions
104
Authorize/Perform Issue Stored Value Function
Issue a stored value card
Issue Functions
105
Authorize/Perform Void Issue Stored Value Entry
Void an issued card
Issue Functions
106
Authorize/Perform Issue Stored Value Batch Function
Issue a batch of stored value cards
Issue Functions
107
Authorize/Perform Void Issue Stored Value Batch Entry
Void a batch of stored value cards
Issue Functions
108
Authorize/Perform Activate Stored Value Function
Activate a stored value card
Issue Functions
109
Authorize/Perform Void Activate Stored Value Entry
Void the activation of a stored value card
Issue Functions
110
Authorize/Perform Activate Stored Value Batch Function
Activate a batch of stored value cards
Issue Functions
111
Authorize/Perform Void Activate Stored Value Batch Entry
Void the activation of a batch of stored value cards
Reload and Redeem Functions
112
Authorize/Perform Reload Stored Value Function
Reload (add credit) a dollar amount to an existing stored value card
113
Authorize/Perform Void Reload Stored Value Entry
Void a reload transaction
114
Authorize/Perform Redeem Authorization Stored Value Function
Perform a redemption authorization
115
Authorize/Perform Void Redeem Authorization Stored Value Entry
Void a redemption authorization
116
Authorize/Perform Redeem Stored Value Function
Perform a redemption transaction (a customer makes a purchase using a stored value card, and the application deducts a dollar amount from the customer’s account)
117
Authorize/Perform Void Redeem Stored Value Entry
Void a redemption transaction
118
Authorize/Perform Manual Redemption Stored Value Function
Perform a manual redemption
119
Authorize/Perform Void Manual Redemption Stored Value Entry
Void a manual redemption transaction
Point Functions
120
Authorize/Perform Issue Stored Value Points Function
Issue points to a stored value card
Point Functions
121
Authorize/Perform Void Issue Stored Value Points Entry
Void the issued points on a stored value card
Point Functions
122
Authorize/Perform Redeem Stored Value Points Function
Perform a points redemption transaction
Point Functions
123
Authorize/Perform Void Redeem Stored Value Points Entry
Void a points redemption transaction
Other Stored Value Card Options
103
Authorize/Perform Manual Entry of Stored Value Card Number
Manually enter the stored value card account number
124
Authorize/Perform Stored Value Cash Out Function
Debit some or all of the remaining balance on a stored value card
179
Authorize/Perform Void Stored Value Cash Out Function
Void a cash out transaction
125
Authorize/Perform Stored Value Balance Inquiry Function
Check a stored value card balance
126
Authorize/Perform Stored Value Balance Transfer Function
Transfer the balance from one stored value card to another
127
Authorize/Perform Stored Value Point Inquiry Function
Check a stored value card point balance
128
Authorize/Perform Stored Value Report Generation Function
Generate stored value card reports
Loyalty Options
166
Authorize/Perform Loyalty Coupon Inquiry
Request a list of coupons that are available for a loyalty account
Loyalty Options
167
Authorize/Perform Accept Loyalty Coupon Function
Redeem a coupon associated with a loyalty account
Loyalty Operations
168
Authorize/Perform Void Accept Loyalty Coupon Entry
Void the coupon redemption
Loyalty Operations
169
Authorize/Perform Issue Loyalty Coupon Function
Issue a coupon to a loyalty account
Loyalty Operations
170
Authorize/Perform Issue Loyalty Points Function
Issue points to a loyalty account
Loyalty Operations
171
Authorize/Perform Void Issue Loyalty Points Entry
Void the point issuance
Loyalty Operations
172
Authorize/Perform Redeem Loyalty Points Function
Accept or redeem points to apply towards the balance of a check
Loyalty Operations
173
Authorize/Perform Void Redeem Loyalty Points Entry
Void the points redemption
Loyalty Operations
174
Authorize/Perform Redeem and Issue Loyalty Points Function
Redeem points and issue additional points to a loyalty account
Loyalty Operations
175
Authorize/Perform Void Redeem and Issue Loyalty Points Entry
Void the points redemption and issuance
Loyalty Operations
176
Authorize/Perform Loyalty Balance Inquiry Function
Request a points balance for a loyalty account
Loyalty Operations
177
Authorize/Perform Loyalty Unique Item Inquiry Function
Request a list of unique menu items that were ordered on a program associated with a loyalty account
Loyalty Operations
178
Authorize/Perform Loyalty Balance Transfer Function
Transfer the points balance associated with one loyalty account number to another loyalty account
Loyalty Operations
180
Authorize/Perform Apply Loyalty Card to Check
Use the Oracle Hospitality Gift and Loyalty operation that applies a card account against the guest check. Depending on the configuration in Gift and Loyalty, setting this privilege could trigger one or more operations, such as redeem points, apply coupons, redeem a gift card, and issue points.
- Click Save.
Related Topics
- Loyalty and Stored Value Configuration Prerequisites
- Setting Loyalty Options
- Configuring the Loyalty Driver
- Configuring the Loyalty Module
- Creating Loyalty and Stored Value Buttons
- Voiding Points on a Re-opened Check
- XProcessor Extension Application Migration
- Setting Stored Value Options
- Configuring the Stored Value Driver
- Configuring the Stored Value Module
- Loyalty Configuration Tasks
- Stored Value Configuration Tasks
Parent topic: Loyalty and Gift Card Interfaces and Drivers
