Configuration Guide Loyalty and Gift Card Interfaces and Drivers Configuring the Stored Value Module Configuring the Stored Value Module Select the Enterprise, property, or revenue center, click Setup, and then click Stored Value Module. Insert a record, enter SVCModule as the name, and then click OK. If you are using Valutec, you can name the module record VTStoredValueModule. Double-click the record to open it. On the General tab, click the Import from a file link. Browse to [Drive Letter]:\MICROS\Simphony2\EgatewayService\handlers, select StoredValueCommandModule.dll, and then click Open. If you are using Valuetec, select VTStoredValueCommandModule.dll, and then click Open. Click the Configuration tab. In the Assembly/Class section, enter information in the following fields: Module ID: Enter the module identification. For Valutec, enter VTStoredValueModule. Display Name: Enter a name for the module (for example, Stored Value or VTStoredValue). Description: Enter a description of the stored value module. Do not leave this field blank. In the Common Properties section, enter information in the following fields: Currency ISO Code: Enter the code (three alpha characters) that represents the currency being used (for example, USD). See www.currency-iso.org/en/home/tables/table-a1.html for a list of Currency ISO 4217 codes. Language ISO Code: Enter the code (two alpha characters) that represents the language being used (for example, EN). See www.loc.gov/standards/iso639-2/php/code_list.php for a list of Language ISO 639–1 codes. If the currency or language is different at the property, override these values at the property level. In the Stored Value Module Properties section, enter information in the following fields: Account Number Maximum Length: Enter the maximum length of a stored value account number (up to 24 digits). Account Number Minimum Length: Enter the minimum length of a stored value account number (down to 7 digits). Cash Module Name: Enter the name of the cash module to use for redemptions (for example, Cash:Cash). Max Card Activation Quantity: Enter the maximum number of stored value cards that can be activated with the Activate Multiple card operation. Max Card Issue Quantity: Enter the maximum number of stored value cards that can be issued with the Activate Multiple card operation. Click Save. Select the property, click Setup, and then click Stored Value Driver. Double-click the stored value card driver record to open it. Click the Override This Record link, and then click Yes to confirm. Click the Configuration tab. From the iCare Driver Properties section, enter information in the following fields: Login: Enter the login for the property ID or the login for the provider. Password: Enter the password for the property ID or the provider. Click Save. Related Topics Configuring Loyalty and Stored Value Privileges Setting Stored Value Options Configuring the Stored Value Driver Creating Loyalty and Stored Value Buttons XProcessor Extension Application Migration Stored Value Configuration Tasks Parent topic: Loyalty and Gift Card Interfaces and Drivers
