- Configuration Guide
- Menu Item Definitions
- Configuring Menu Tag Groups and Tags
A delivery service provider menu is a collection of Simphony menu items. Use a menu tag to associate a Simphony menu item with the delivery provider menu. Each provider must have a unique menu tag in Simphony. Only the menu items with these tags are visible in the delivery provider application.
You need to have the role privilege to view, edit, add, or delete tags. Creating Employee Roles contains more information about setting these privileges for tags in the Roles module, EMC Modules tab.
Simphony retains all tag activity (including add, edit, and delete) for use in auditing.
- To add a tag group:
- Select the Enterprise level, click Descriptors, and then click Tag Groups.
- Click the insert icon (
) on the toolbar.
- Add a new tag group record with the appropriate name, and then click OK.
- Click Save.
- To add a tag:
- Select the Enterprise level, click Descriptors, and then click Tags.
) on the toolbar.
- Add a new tag record with the appropriate name (for
example, Online Only), and then click OK.
You cannot duplicate tag names.
- Select the Tag Group.
- Click Save.
- To edit a tag:
- Change the tag name in the Name column.
- Click Save.
- To delete a tag:
If you delete a tag that is associated with a menu item definition, the association is also deleted.
- Highlight the tag record, click the delete icon (
) on the toolbar, and then click Yes.
- Click Save.
- To associate a tag with a menu item definition, see Associating a Menu Item Definition with a Tag for detailed instructions.
Parent topic: Menu Item Definitions
