Configuring Print Classes for Pre-Production Chits
To configure and assign printers to a pre-production Print Class:
  1. Select the Enterprise or property, click Configuration, and then click Print Classes.
  2. Insert a new record and enter the name of the pre-production print class in the Name field (for example, Print Pre-Production Chit).
  3. Configure settings within the Options section as needed.
  4. Select the Routing Group from the drop-down list in the Output section.
    Typically, enabling the 0 - Use Order Devices routing group suffices for most pre-production chit printing tasks.
  5. Enable the order devices that are to serve as a pre-production remote printers.
  6. Click Save.
