Configuring Tender/Media - Service Total Records for Pre-Production Chits
To configure Tender/Media - Service Total records for pre-production chit printing:
- Select the Enterprise or property, click Configuration, and then click Tender Media.
- Insert a new record, and enter the name of the pre-production service total record (for example, Print Pre-Production Chit).
- In the General Settings section, assign a Privilege Group that allows users to use this service total.
- In the Key Type field, select 2 - Service Total from the drop-down list.
- Configure the remainder of the General tab settings, and then click the Options tab.
- Click the Printing Options tab, and then enable the 98 - Print Pre-Production Chit option.
- Click the Ops Behavior tab, and then select 2 - Hold Order as the Tender Media Hold Type from the drop-down list.
- Configure the remainder of this service total record’s settings.
- Click Save.
