Making Menu Items Refillable and Configuring the Refill Limit
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Classes.
- Double-click a menu item class to open it.
- Click the Options tab, and then select 72 - Enable Refill.
- Click the General tab, and then enter maximum number of refills customers can order in the Maximum Refill Count field. The maximum refill count is 99.
- Enter a label (for example, Refill) to identify refill items on printed order chits in the Refill Descriptor field. Up to 12 characters are allowed.
- Click Save.
- Repeat Steps 2 through 6 for all menu item classes that are refillable.
Parent topic: Menu Item Refills
