Allowing Employees to Refill Menu Items
- Select the Enterprise level, click Configuration, and then click Roles.
- Double-click the role type record (for example, administrator, manager or server).
- Click the Operations tab, click the Transactions subtab, and then select 186 - Perform Menu Item Refills.
- Click Save.
Related Topics
Parent topic: Menu Item Refills
