Configuring the Log Files for Oracle MICROS Reporting and Analytics
  1. Select the Enterprise level, click Setup, and then click Enterprise Parameters.
  2. Click the mymicros.net tab, and then enter the appropriate information. The following table describes the fields.
    Table 45-4 Reporting and Analytics Settings
    Field Description
    Logs to Keep
    Enter the number of Data Transfer Service (DTS) logs to retain.
    Error Files to Keep (days
    Enter the number of days the application retains error file logs.
    Verbosity
    Select the Verbosity level for DTS logging. You should typically set this value to Normal. Set verbose logging to Extended or Super for troubleshooting as these elevated levels create large log files and slow performance.
    mymicros.net Machine Name
    Enter the name of the Reporting and Analytics server computer using the format http://[YourReportingAndAnalyticsUrl].
    Enterprise mylabor URL
    If DTS uses a different Internet Protocol (IP) address to connect to Oracle MICROS Labor Management, enter the URL. Use the format http://[Name or IP address of the Reporting and Analytics portal server].
    If you leave this field blank, DTS uses the Reporting and Analytics machine name to post Labor Management. Workstations do not use this URL.
    Organization ID
    Do not change this value unless instructed by your Oracle representative.
    This field represents the Enterprise organization ID used for reporting to Oracle MICROS Reporting and Analytics.
    17 - Send selected translations to Simphony Reports
    Select this option to send definition translations to Simphony reports. You must also select the Send Translations for this Language to Simphony Reports option from the Language module for each language to be sent to Simphony reports.
  3. Click Save.
The Oracle MICROS Reporting and Analytics User Guide, located at http://docs.oracle.com/en/industries/hospitality/, contains information about enabling reports in Reporting and Analytics.
