Creating Enhanced Dining Tables
You can use all functions of the Simphony TMS using enhanced dining tables. You cannot use legacy standard tables with TMS. Enhanced dining tables show overlays on the outer edges of the table that indicate status, coursing, and alerts.
- Select the Enterprise, property, or revenue center, click Configuration, and then click Page Design.
- Double-click the page on which to define enhanced dining tables.
- On the Edit tab, select the page area on which to place the enhanced dining tables.
- Click Other..., select Table Management, and then select Dining Table (Enhanced).
- Move and adjust the table size on the page. Leave space between tables on the page layout to ensure visibility of indicators and table state. You can increase the grid configuration on the page from 24 (default) to 48 using the Change Grid Size link.
- Set the unique properties of the enhanced dining table:
- Repeat Steps 4 through 6 to create additional enhanced dining tables.
- Click Save.
Parent topic: Dining Room Tables and Seating
