Database Size Reduction and System Performance Improvement
To reduce the data footprint of the Simphony Transaction database and to improve overall system performance, you can change the Data Transfer Service (DTS) and data Purging job settings. For brand-new installations, default DTS and Purge job settings have been assigned to assist in controlling the amount of data that is getting stored.
After performing an upgrade, you are required to enable a new employee Roles option to grant permissions for those employees deemed responsible for editing these job settings going forward.
See the Configuring Access Privileges for Data Transfer Service (DTS) and Data Purge Job Settings section for instructions for configuring the access privilege.
Listed in the tables below, are the default DTS and data purge job settings.
Table 2-1 Default DTS Job Settings
| Default DTS Job Name | Job Settings - Number of Days |
Authorizations |
2 |
Definitions |
15 |
Journals |
2 |
Simphony Database Purge |
30 |
Command Module Maintenance |
60 |
Mymicros.net Daily Aggregation |
15 |
Time Zones |
30 |
Labor Definitions |
15 |
Table 2-2 Default Data Purge Job Settings
| Default Purge Job Name | Job Settings - Number of Days |
Activity Log |
30 |
Audit Trail |
90 |
Authorization Log |
30 |
Checks |
7 |
Client Event Log |
30 |
CM Transaction Detail |
7 |
Import Export |
30 |
Journals |
7 |
KDS Details |
7 |
Queued Checks History |
7 |
Signature Capture |
7 |
Time Cards |
60 |
Totals |
7 |
Transaction Log |
90 |
