Configuring Access Privileges for Data Transfer Service (DTS) and Data Purge Job Settings
The option named 10066 – Enable Access to edit Job/Purge Settings, allows you to control who has access to changing the Data Transfer Service (DTS) and data Purge job settings. For Simphony version 19.1 fresh installations, default DTS and Purge job settings have been assigned to assist in controlling the amount of data that is getting stored. After performing an upgrade, you are required to enable this employee Roles option to grant permissions for those employees deemed responsible for editing these job settings going forward.
To locate and enable the option:
- Select the Enterprise level, click Configuration, and then click Roles.
- Click the Operations tab and scroll down to the Miscellaneous Options section.
- Enable the 10066 – Enable Access to edit Job/Purge Settings option and Save.
