Configuring the Same Credentials for All Properties in the Enterprise
- In the EMC, select the Enterprise level, click Setup, and then click Enterprise Parameters.
 - Click the Security tab, and then select Use Same Credentials for All Properties.
 - Select the property whose credentials you want to use, and then enter the New Install User Security Password.
 - Re-enter the new security password in the Confirm User Security Password field, and then click Save.
