4 Updating Property Administrator and Database Logon Credentials
When logging on to the EMC for the first time after installing or upgrading Simphony, a message indicates that the property credentials are not compliant with the Simphony standards. To keep the properties safe from security risks, you need to update the Admin and Database credentials, which Simphony uses to create and maintain the workstation databases. Simphony offers the options of configuring security credentials for each property separately or using the same credentials for all properties in the Enterprise. Simphony requires that you update the system and database administrator credentials every 90 days. If you do not update the credentials, EMC shows the Database Credentials Non-Compliance message each time you log on until you meet the compliance.
To configure credentials for each non-compliant property separately, see Configuring Different Credentials for Each Property.
To configure the same credentials for all non-compliant properties in the Enterprise, see Configuring the Same Credentials for All Properties in the Enterprise.
