Setting the Max Allowed Failed Logins for EMC Access
MFA adheres to the EMC account lock out setting.
Select the Enterprise, click Setup, and then click Enterprise Parameters.
Click the Login tab.
In the Options section, enter the value for the Maximum Allowed Failed Logins field.
After reaching the failed login threshold (based on entering
an invalid EMC user or OTP password), users are notified that their
login was rejected by the system and that their account is currently
locked out.
