Interface Ports
All TCP ports used for Simphony interfaces are configurable from within the interface configuration of EMC. The following are the default TCP ports for common interfaces:
Table 4-3 Default Interface Port Numbers
| Interface | Port Number | Configurable? |
Table Management System |
5006 |
Yes |
Property Management System |
5007 |
Yes |
Credit Authorization |
5008 |
Yes |
System Interface Module (SIM) |
5009 |
Yes |
Parent topic: Port Numbers
