Traffic Note
In general, all traffic is initiated by the workstation and requires only outbound TCP connections to the outside of the property. Check the site configuration as there are likely be exceptions to this rule.
Other ports: Check the wrapper.conf file for environment-specific Reporting and Analytics (formerly myMicros ports). The file’s location is: [Drive letter]:\MICROS\mymicros\myPortal\server\default\wrapper.conf.
Note that for workstations running on Linux for MICROS, SSH is used for support. Therefore, SSH inbound might be needed for these connections (normally Port 22). If this port is intended for a local connection only, take measures to restrict wider access (that is, on WAN Firewall).
