Assigning MFA EMC Access Privileges
To access and configure MFA security for other users on your system, you need to be assigned the correct privileges in the EMC.
  1. Select the Enterprise level, click Configuration, and then click Roles.
  2. Click the EMC Modules tab and scroll to the Personnel section.
  3. Select the check boxes for the Employees (Enterprise) access privileges for each of the following columns:
    • View
    • Edit
    • Add
    • Delete
    Figure 2-2 Roles Options for Assigning MFA Privileges
    This figure shows the Roles options for assigning MFA access privileges.
  4. Click Save.
  5. Click the Actions tab, scroll through the Action column until you reach the Security section, select the Can Change Others’ Passwords check box, and then click Save.
    Figure 2-3 Roles Option for Changing Other's Passwords
    This figure shows the Roles option for Changing Other's Passwords.
  6. Ensure that all users requiring MFA configuration permissions are assigned a Role that have these access privileges enabled.
