Printing a Memo Check
  1. Pick up a check that has menu items from multiple seats.
  2. Filter the check by the seat numbers for which you want to print the memo check.
    See Filtering a Check by Seat Number for instructions.
  3. (Optional) Tender the check using the guest’s payment method.
  4. Press the Print Memo Check function key.
