Removing a Deposit From a Check
- Pick up the check with the deposit.
- Select the deposit information on the check, and then press the Void function key.
- Select the rental menu item or service charge, and then press the Void function key.
- Perform either a service total or tender the check.
Parent topic: Rental Deposits
