Applying a Return
- To return one menu item:
- Pick up a check or begin a new check, and then click the Return function key.
- Add the menu item to return to the check.
- End the current service round or close the check.
- To return more than one menu item:
- Pick up a check or begin a new check, and then click the Transaction Return function key.
- Add the menu items to return to the check.
Parent topic: Discounts and Service Charges
