Applying a Condiment Discount
You can apply a condiment discount manually, automatically, or with a coupon.
- To apply a discount manually:
- Add a parent menu item to the guest check.
- Add the condiment that is configured to apply a discount.
- Click the button that is configured for the manual condiment trigger function. Simphony applies the discount to the guest check.
- Close the transaction.
- To apply a discount automatically:
- Add the condiment that is configured to apply a discount. Simphony applies the discount to the guest check.
- To apply a discount using a coupon:
- Click the button that is configured for the coupon condiment trigger function. Simphony applies the discount to the guest check.
Parent topic: Discounts and Service Charges
