Starting and Ending an Event
You must have the privileges to manually start and end an event.
Events that are configured to automatically start or end will do so automatically at the preset date and time. No manual intervention is needed.
When a workstation is offline and has no connection to the Check and Posting Service (CAPS), events cannot start or end (automatically and manually).
Related Topics
Parent topic: Events
