Event Status Bar
The event status bar allows you to view the event name when posting check sales. The event status bar is typically configured to appear in the upper or lower area of the POS client page.
Depending on the status bar configuration, you can see some or
all of the following information in the event status bar for the workstation
operator and the current check detail:
Event name
Event short code
Actual start date and time of the event
End date and time (If the event is set to automatically end, the end time appears with an asterisk, such as 25/06/2017 11:00pm*.)
Depending on the status bar configuration, you can view the information while signing on or off of a workstation, and in a transaction.
Related Topics
Parent topic: Events
