Posting Checks to a Closed Event
You can add a check to an event that is closed. For example, when you end a wedding event at the workstation, and then a wedding guest orders a last minute drink, you can post that check to the closed wedding event.
You must have the privilege to associate a check with an event that has ended.
  1. Select the function key to begin a check or fast transaction. The Select Check Event list appears and includes closed events for the past seven days (including today).
    Closed events appear in the list preceded by an asterisk (*).
  2. If the event does not appear in the Select Check Event list (because it occurred more than seven days ago), select Change date to show ended Events, and then click OK.
    You can view closed events for up to 60 days in the past (including today).
  3. Select the date from the calendar, and then click OK. All closed events from the selected date to the current date appear.
  4. Select the closed event, and then click OK.
  5. Add menu items, and then tender the check using the guest’s payment method.
