Enabling Single Item Per Suborder (SIPS)
When using KDS Capacity Scheduling, the prep station displays need to have Single Item Per Suborder (SIPS) enabled. This means that every menu item on the order has its own chit on the prep station display.
- Select the revenue center, click Setup, and then click Order Devices.
- Double-click the KDS order device record for a prep station to open it.
- Click the Options tab, and then select 3 - Single Item Per Sub-Order.
- Click Save.
- Repeat these steps for each prep station display.
Parent topic: KDS Capacity Scheduling
