8 KDS Capacity Scheduling
If a prep station can handle the group’s order simultaneously, the items are displayed so they are ready to serve at the same time. The items may have to wait to appear on the display if the capacity is currently unavailable.
If a prep station cannot handle the group’s order simultaneously, the KDS breaks the order down into groups of items.
Typically, items which take longer to prepare should appear at prep stations on KDS displays before items with lesser prep times. There is some flexibility built into KDS Capacity Scheduling where exceptions can be made, and all items can show on KDS displays (based on their capacity settings), effectively overriding a menu item’s prep time settings.
KDS Dynamic Order Mode (DOM) is not supported.
Only non-DOM KDS Chit Styles are supported.
Single-Item Per Sub-Order (SIPS) must be enabled.
KDS load balanced systems are not supported.
KDS Capacity Scheduling applies only to prep station devices. The algorithm ignores devices configured as Expo Displays or Speed of Service (SOS) Displays.
Rush or VIP orders do not have an effect when KDS Capacity Scheduling is enabled.
RVC Parameters
Order Devices
KDS Displays
KDS Controllers
Menu Item Maintenance – Menu Item Definitions
Menu Item Classes
Order Type Parameters
Kitchen Themes
Components
- Examples of Capacity Scheduling Scenarios
- Disabling DOM-Related Options for KDS Capacity Usage
- Enabling Single Item Per Suborder (SIPS)
- Disabling Load Balancing and Enabling Capacity Scheduling
- Setting the Relative Capacity for Each Order Device
- Setting the Relative Capacity Used By Each Menu Item
- Setting the Relative Capacity for Each Order Device in a Kitchen Theme
- Setting the Relative Capacity for Each Component
