Setting the Relative Capacity for Each Order Device
The following steps describe how to set the relative capacity for configured order device panels in the KDS Display.
- Select the property, click Setup, and then click KDS Displays.
- Select the KDS display record, and then click the Display tab.
- In the Display Screen Options section, set the appropriate capacity value in the Panel Configuration table for each configured panel.
- Click Save.
Parent topic: KDS Capacity Scheduling
