Alternately, you can configure the system to ignore or override
the KDS Prep Time and capacity settings. There are settings in the
Menu Item Classes and Order Type Parameters modules which affect KDS
capacity output to KDS displays. These option locations are shown
below (by module):
Menu Item Classes
12 - Always Use KDS Prep Time: This option suppresses
the Menu Item Classes options 83 and 84.
See KDS Capacity Scheduling, specifically
the Examples of Capacity Scheduling Scenarios section to review examples of various KDS output scenarios and how
configuration settings affect this feature.
See the Oracle
MICROS Simphony Configuration Guide, specifically the Menu Item Classes chapter, for more information about
configuring menu item classes.
See the Oracle MICROS Simphony
Configuration Guide, specifically the Order Types section for more information about configuring order types.
