Setting the Relative Capacity for Each Order Device in a Kitchen Theme
The following steps describe the optional configuration for your order device(s) capacity settings in a kitchen theme.
- Select the property, click Setup, and then click Kitchen Themes.
- Select the record, and then click the KDS Client tab.
- In the Panel Configuration section, set the Capacity to the desired value.
- Click Save.
Parent topic: KDS Capacity Scheduling
