Setting the Relative Capacity for Each Component
The following steps describe the optional configuration for capacity settings in the Components module.
- Select the Enterprise level, click Configuration, and then click Components.
- Select the record, and then click the General tab.
- In the Capacity section, set the Capacity Usage to the desired value.
- Click Save.
Parent topic: KDS Capacity Scheduling
