Importing Current Settings to a Kitchen Theme
You can import existing configuration information to a kitchen theme record.
- Select the property, click Setup, and then click Kitchen Themes.
- In table view, right-click the record to which you want to import the settings, and then select Import Current Settings to Kitchen Theme.
- Change the settings as appropriate, and then click Save.
Parent topic: Kitchen Themes
