Configuring the Deployment Schedule to Install CAL on a Workstation Without the POS Interface
- Select the Enterprise, click Setup, and then click CAL Packages.
- Select Service Host Prereqs from the left pane for all POS clients.
- Click the Deployment Schedule tab, and then click Add Deployment.
- From the Deployment Type column, select 2 - Specific Service Host.
- In the Service Host column, click the ellipsis (...) point button, select the CAPS workstation, and then click OK.
- In the Action To Take column, select 0 - Install, and then click Save.
- Select Service Host from the left pane, and then repeat Steps 4 through 7.
