CAL Installation Prerequisites for a Workstation Without the POS Interface (CAPS-Only Workstation)
Configure a service host for CAPS. Configuring the Service Host for CAPS Running as a Service on a Client contains more information.
Assign the employee privilege to download software, install, and authenticate clients and Service Hosts using CAL.
Users must have the employee privilege assigned to the appropriate role to successfully authenticate workstations, Android devices, and Kitchen Display Systems (KDS). After installing or upgrading to Simphony release 2.9.1 or later, you must assign the privilege to a user’s role. When the Role option is set, employees can use their EMC logon credentials when CAL’ing devices. Allowing Employees to Install and Authenticate POS Clients and Service Hosts contains more information on assigning the privilege.
Set the CAL deployment schedule. Configuring the Deployment Schedule to Install CAL on a Workstation Without the POS Interface contains more information.
