EMC Record Translation
In the EMC, you can translate the name of any record into multiple
languages using the Text Translation dialog. This dialog is invoked
by the Language Translation icon (
) on the
toolbar (or using the shortcut key F8). The Language Translation icon
only becomes active when a translatable text field or a translatable
table view cell is active in the module. This icon is dimmed if:
![This image shows the Language Translation icon, which is a lowercase letter e with an accent. This image shows the Language Translation icon, which is a lowercase letter e with an accent.](img/translate_emc.gif)
Only one language exists in the Enterprise
You do not have Edit access for the selected module
Translated text saves when the record itself is saved. Therefore, if you perform an undo operation on a record, record translations are also reverted.
Related Topics
- Configuring Translation Privileges
- Configuring Languages
- Configuring Workstation Translations
- Configuring the EMC Translation Files
- Translating Menu Item Records
- Translating Touchscreen Buttons
- Setting Languages for the Property
- Setting the Default Language for a Workstation
- Configuring Screen Language Buttons
- Copying Translations from One Language to Another
- Exporting a Translation File
