Exporting a Translation File
After you modify a language file, you can export it and then import it into another system.
Related Topics
- Configuring Translation Privileges
 - Configuring Languages
 - Configuring Workstation Translations
 - Configuring the EMC Translation Files
 - Translating Menu Item Records
 - Translating Touchscreen Buttons
 - Setting Languages for the Property
 - Setting the Default Language for a Workstation
 - Configuring Screen Language Buttons
 - Copying Translations from One Language to Another
 - Language Settings and Translation
 - Language Translation Configuration Tasks
 - EMC Record Translation
Parent topic: Language Settings and Translation
