29 Weighed Menu Items
                        Manual: The workstation operator is prompted to enter the weight of the item if the scale is not connected.
                        Automatic: A scale attached to a workstation can automatically calculate the weight of the item.
Tare weight is the weight of a container or wrapper that is deducted from the gross weight to obtain the net weight. For example, in a restaurant with a salad bar where salad is sold by weight, the customer should not be charged for the weight of the container. To prevent this, a tare weight is configured for the salad menu item, and the weight of the salad’s container is automatically subtracted from the weight of the salad.
                        Kilograms: 0.000
                        Pounds: 0.00
                        Ounces: 0.0
The UOM must match in the Enterprise Management Console (EMC) configuration and on the scale setting. For example, the scale must measure in ounces and EMC must be set to use ounces.
