Configuration Guide Number Look Up (NLU) Configuring NLU Groups Configuring NLU Groups An NLU Group contains menu items that workstation operators can scan with a barcode scanner to look up items. Select the Enterprise, property, revenue center, or zone, click Descriptors, and then click NLU Names. In the Text field, enter the NLU Group name (for example, Barcode Items). You can configure up to 32 NLU Groups. Click Save. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Maintenance. Select a menu item record (for example, potato chips). Select the NLU Group to associate with the menu item. Enter the NLU number or barcode value in the NLU Number field. Repeat Steps 5 through 7 for each menu item that associates with an NLU Group. Click Save.
