Fingerprint Scanning
                        Oracle MICROS Tablet E-Series
                        Oracle MICROS Workstation 6 Series
                        Oracle MICROS Workstation 5a
                        Oracle MICROS PC Workstation 2015
                        A PC running a Simphony client that is attached to the PC with a USB connection
                        Signing in to a workstation
                        Clocking in and out
                        Authorizing privileged operations
                        Enroll themselves and other employees’ fingerprints in Simphony
                        Register up to ten different fingers (in the event that employee digits become incapacitated (cut, removed, or bandaged))
At registration, the employee places a finger on the fingerprint reader. The reader scans the fingerprint and captures its characteristics (an array of pixels) as Fingerprint Image Data (FID). The reader then extracts fingerprint features as Fingerprint Minutiae Data (FMD) and creates a data record that is stored in database tables in the cloud and in the POS clients where the employee signs in. At sign-in, the reader captures fingerprint data and then uses FMD records to search the local database for a match. If a match is found, the action is performed (such as sign-in). The system does not store pictures, photographs, or images of the fingerprint. There is no way to reconstruct the fingerprint using the stored data.
Auditors can determine whether an employee performed an authorization using a fingerprint reader, manual entry, or magnetic card swipe.
Simphony does not store the fingerprint image. Simphony uses only a mathematical identification of the image. The data stored is similar to a hash of the fingerprint and cannot be used to reconstruct the fingerprint. Collecting or enrolling employee fingerprints is a privileged operation, typically requiring manager authorization. The data is protected at rest and in transit within the Simphony application using the same approaches that all sensitive data is protected. When an employee is deleted from the system, the stored fingerprint data for that employee is also deleted. This applies to all storage at the enterprise and on premise. In current versions, the timing of when an employee is deleted from the system is determined by when a privileged user manually deletes the employee record in EMC.
                        To show the count of employees with any biometric data:SELECT count(*) AS "EMPLOYEES WITH BIOMETRIC DATA" FROM EMPLOYEE WHERE fingerprinttemplate1 IS NOT NULL or fingerprinttemplate2 IS NOT NULL or fingerprinttemplate3 IS NOT NULL or fingerprintnewtemplate1 IS NOT NULL or fingerprintnewtemplate2 IS NOT NULL or fingerprintnewtemplate3 IS NOT NULL;
                        To show employee and fingerprint columns:select FIRSTNAME, LASTNAME, FINGERPRINTTEMPLATE1, FINGERPRINTTEMPLATE2, FINGERPRINTTEMPLATE3, FINGERPRINTNEWTEMPLATE1, FINGERPRINTNEWTEMPLATE2, FINGERPRINTNEWTEMPLATE3 from EMPLOYEE;Note: -
                                    Neurotec templates are stored in FINGERPRINTTEMPLATE1, FINGERPRINTTEMPLATE2, FINGERPRINTTEMPLATE3
                                    UrU templates are stored in FINGERPRINTNEWTEMPLATE1, FINGERPRINTNEWTEMPLATE2, FINGERPRINTNEWTEMPLATE3
