Configuring the Workstation Employee Fingerprint Sign In Options
  1. Select the property, click Setup, and then click Workstations.
  2. Double-click the workstation to use with a fingerprint reader.
  3. Click the Options tab.
  4. Select the appropriate security options as described in the following table.
    Table 45-6 Employee Security Options
    Option Selecting This Option Requires That All Employees …
    47 - Fingerprint Scan Required for Employee ID
    Scan a fingerprint.
    48 - Employee ID or Fingerprint Scan Required for Employee ID
    Scan a fingerprint or enter the employee ID number.
    49 - Employee ID and Fingerprint Scan Required for Employee ID
    Scan a fingerprint and enter the employee ID number.
    50 - Mag Card or Fingerprint Scan Required for Employee ID
    Scan a fingerprint or swipe an employee ID card.
    51 - Mag Card and Fingerprint Scan Required for Employee ID
    Scan a fingerprint and swipe an employee ID card.
  5. Click Save.
