Configuration Guide Guest Checks Setting the Hold and Fire Tender Notification Setting the Hold and Fire Tender Notification Select the revenue center, click Setup, and then click Control Parameters. Click the Options tab, and then select 66 - Enable Hold and Fire Final Tender Notification. This notification indicates that unfired menu items are on a check during the final tender process. Click Save. Related Topics Order Handling on Open Checks Holding and Sending Items to Order Devices
