Setting the Employee Auto Sign Out Period
To automatically suspend a check and sign out an employee, you need to define the automatic operator popup interval.
- Select the Enterprise, property, revenue center, or zone, click Setup, and then click Control Parameters.
- Click the Configuration tab.
- In the Automatic Operator "Popup" Interval (min:sec) field, enter the amount of time (in minutes and seconds) that the workstation waits before signing out an inactive popup workstation operator.
- Click Save.
Related Topics
