Configuring Condiment Sets
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Condiment Sets.
  2. Insert a new record, enter a name for the condiment group, and then double-click the new record.
  3. Click Add from the Condiments section.
  4. From the Menu Item column, click the ellipsis point (...) button, select a condiment from the list, and then click OK.
  5. Enter the number of condiments that accompany the condiment group in the Default Count field.
    For example, if the condiment is a slice of cheddar cheese and you enter number 2 as the default count, 2 slices of cheddar cheese accompany the condiment.
  6. In the Sort Order field, enter the order in which the workstation shows the condiment on screen.
  7. If you want the condiment to remain in the order when the workstation operator changes a menu item to plain (for example, when a workstation operator changes the order to a plain bacon cheeseburger, the bacon and the cheese are not removed), click the ellipsis point (...) button from the Options column, select 1 - Persist On Plain, and then click OK.
  8. Enter the Menu Item Definition Sequence number that coincides with this condiment.
    The Menu Item Definition Sequence number helps workstation operators switch between condiments. For example, the cheeseburger has two menu item definitions. If the customer orders definition 1, the cheeseburger should have cheddar cheese and if the customer orders definition 2, the cheeseburger should have mozzarella cheese. When configuring the condiment group for the cheeseburger, you must enter 1 as the Menu Item Definition Sequence for the condiment cheddar cheese and 2 as the Menu Item Definition Sequence for the condiment mozzarella cheese.
  9. Repeat Steps 3 through 8 to add more condiments to the condiment group.
  10. Click Save.
